| | | Forums66 Topics128,078 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | I have a 51 chev pickup, and I'm changing the motor from a 216 to 235ci. its out of a 55 chev with auto trans. So it has solid lifters and full oil pressure. I took the motor apart to clean everything and check bearings. and so on. I took the oil pump apart to check gears and misplaced the gasket! I read where you need to get a gasket from Chevrolet. nothing else will work.(true or false)so where do you get a gasket for a 1955 235ci from Chevrolet mafg. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
Most likely, some one else will post info on the oil pump gasket. If not, get gasket material and make a gasket.
Did you engine come from a car (Powerglide transmission - that engine would have had hydraulic lifters) or did is come from a truck (Hydra-Matic transmission - that engine would have had mechanical/solid lifters)?
To confidently identify the engine (it may be a replacement engine), post the engine serial number: it is pressed into the block, just to the rear of where the distributor goes into the block.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | that would be false, it is just a gasket, there is no magic involved. You would have to get one the proper thickness, (what that would be I have no idea) But I'm thinking what ever will give the proper clearance should be what you will need. There may be some NOS gaskets out there, however it will probably be pretty dried up by now, probably could soak it in some diesel or something to soften it up. But I am pretty sure chevy stopped making those many years ago. You could try jim carter, chevs of the 40's, egge to start with. there are others, but between these three and the place down the street I haven't had to go anywhere else. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think I remember seeing them in an engine gasket set but not all sets come with them. They are quite thin. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe someone who rebuilt a 54 or later 235 engine and used a new oil pump would have a spare oil pump gasket? The Fel-Pro set includes:
Oil pump mounting gasket Oil pump pickup tube gasket Oil pump oil seal
