| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | I am using the engine from a 350 pontiac for my build Iam trying to figure the oil line set up .Ihave two lines running from the oil filter housing they go around to the front of the engine I am not sure were they went to .Can they be removed and a reguler filter system be installed.I relize it seems like a crazy question, but the engine was was out when it was brought to me. Tony | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Those lines would have gone to an oil cooler. You can take the adapter off the block and put an oil filter adapter on. | | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | Thank you for the information it is what i needed to know. You guys have always been there for me. Thank you. I have been taking pictures of the build and hopefully will be posting them by the end of the summer.Tony PS [ There is a 1/4 inch threded hole just above the oil filter housing the hole is empty does anyone know what was in there or what could it be used fo ] | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It is probably 1/8" pipe thread, its for a oil pressure switch | | |
