4 members (Otto Skorzeny, Johnny Rib, dwreills, 1 invisible), 95 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#944285 05/19/2013 1:03 PM
install new rubber and glass in back window of my 48 gmc,it is raining and is leaking around bottom of rubber, pretty much the whole bottom...
696969 #944312 05/19/2013 2:33 PM
Could be leaking under the top of seal and then traveling down and coming out on the bottom. Recommend going to you local auto glass shop and have them seal it. I have used an asphalt sealer in a caulking gun with success in the past. Rainfall here is light, not like Glens Falls, so you may be best served letting the pros do it.
Ed
696969 #944349 05/19/2013 4:51 PM
that is what I was thinking, I will get some silicone and try it myself first, doesn't work, I will leave it up to the pros...thanks forty9 for info...
696969 #944603 05/20/2013 5:57 PM
696969 Be careful what sealer you use,especially if you plan any paintwork around that area in the future,I would try and avoid silicon based sealers.
Your best bet is to find a butyl based compound it's non setting and non aggressive (it wont hurt your paint)
I'm not sure if it's available your side of the pond but I use a product called Arbomast ,it's designed specifically for the problems you describe.
Failing that,talk to your local auto glass shop,they might be able to suggest a suitable alternative.
More pix on Flickr.
696969 #944800 05/21/2013 2:09 PM
Get some urethane from a glass shop to seal it.
My 46 GMC on Photobucket
696969 #944811 05/21/2013 3:12 PM
the urethane is for more modern stuff. I'd go with the buytl type or similar. For the rear window I'd pull the lock strip out,(if its the same as TF) and then use a plastic type tool to pull or pry the seal up some to inject the sealer behind it. If its fairly new paint maybe some tape around the whole area where your prying etc.
The so called experts aren't always so expert, so watch out if its something you care about and don't want ruined some how.
I have a brother with a good story about having the experts work on his car.
Truckrolet #944964 05/22/2013 8:19 AM
X2
you need to get the sealant UNDER the rubber not just along the edges or it will leak later and start rusting in there.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Truckrolet #946389 05/28/2013 4:44 PM
I'm not sure why it matters that urethane is for newer stuff? Assuming you're putting in a new rubber anyways, it will probably seal much better and it's made specifically for sealing metal to rubber to glass connections.
46gmcpu #946543 05/29/2013 8:01 AM
urethanes set hard and the butyls set soft. If you use a urethane it will be a bear to replace in the future.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
