Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Charles in CA, crenwelge, UtahYork, TexasFarmTruck, Mike1933), 163 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#94456 01/29/2006 9:42 PM
I just tested my 6-volt battery with a hydrometer. 2 of the cells are showing full charge. One cell shows 1/2 charge. Does this denote a bad cell or does it simply need more charge?
Mike
1951 Chevy 3100 w/235
Mike,
I think this usually means that cell is bad. If you have somehow to load test the battery you can watch this cell and it will bubble and off gas..proof it is going south.
If you charge the battery for the prescribed time and the cell is still low, it is probably bad. Usually a shorted cell won't allow the battery to take a charge. If it isn't a critical transportation issue, charge it and drive it...if it is going to croak, it will surely let you know.
The SG on a fully charges 6 volt should be 1.265. The allowable difference between cells is .050. 50% charge in SG (specific gravity) is 1.190. If you add 1.190 and .050 = 1.240, which is less than the 1.265 specific gravity.
This is classroom stuff...see if it works in the real world. Charge the battery again and drive the truck. Take jumper cables!
Stuart
Thanks automarc! I have one of the "new fangled" hydrometers with the floating balls. I have not gotten the truck started yet. It is cranking slow after a full charge, and if I turn the interior light on, it dims while cranking.
Can NAPA load test a battery? I bought it from them last spring.
take it back to the seller - it's defective!
