5 members (DadsFirstPickup, 5 Window 9434, TUTS 59, Jon G, 1 invisible), 111 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
Replaced the bias plys with radials 215/85/16, and man what a difference! Couldn't even drive the darn thing in winter, the old bias would shake the doors off.
VERY pleased so far. I like the tall skinny look and was afraid the radials wouldn't be. But they are. Nice blocky shoulder, not the wrap around look of most radials.
Capitol H/T brand. The shop had Firestones for not much more money but I didn't like the look. Will post a link to pics this evening.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Matthew 6:33
Are those tube type radial tires? If not, keep a close eye on your tire pressures, as tubes are known to fail prematurely when used in tubeless tires, whether they are "radial" tubes or not.
Bill Burmeister
They look like they belong on that fine looking truck. You've already discovered there is a world of difference in ride and handling.
Indeed they look nice and the truck is great looking !
I have replaced my bias with radials but have not been able to drive it yet due to other stuff being done... Almost done though..get alignment tomorrow then it'll be on the road for a bit.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
looking good. Thank you for posting, I just picked up a set of used Michellins last sat. A few more paydays away from mounting.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Crusing in the Passing Lane
Be careful buying used radials, even Michelins-they seem to fail internally for no particular reason other than old age(rust around a patch?) Had several brands do this-Goodyear, Michelin.
Scott, your Korean era truck looks darn nice. I want to build my '53 just like it. Did you notice any increased low speed steering effort with these tires over the bias tires?
Could you measure your contact patch and over height of the tire?
Also, did this fit on the stock narrow rim ok?
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
These seem to require less steering effort at low speeds than the bias plys and fit great on stock rims. The rolling radius of the tire, one complete revolution is very close to 93 inches, and if memory serves you can divide pi (3.14) into that and get the overall height, which would be approx 30 inches.
Or could just measure straight across when I get home. Always do things the hard way, that's my motto. :-(
Matthew 6:33
Very original looking tires. Thats what I want thanks for the info.
Thanks Scott. I will pm you.
Steve
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Socket Breaker
Socket Breaker
Looking good...
-W
Scott,
Your truck and these tires look great. I'm considering putting 215/85R16's on my 1955.1 model 3100, and your photos really helped me out.
What tire pressure do you use?
Trooper Jeff
Trooper Jeff
If I can't drive my truck, fetch my horse
"Courage is saddling up even though you are scared to death" - John Wayne
Those are great looking tires!!! I could shave with the finish on that truck.
Running 38 lbs right now and will probably drop to around 34 which is what I ran the old bias plys at. They're 10 ply and the tire shop indicated they might ride a bit rough, but they're so much smoother than the bias, it's like round versus square...literally. They even feel smoother over stuff like pavement seams and bridge joints. It's like getting a new set of shocks almost.
Matthew 6:33
Thanks, it photographs well. It's pretty lumpy by show truck standards.
Matthew 6:33
bump
Scott;
I love your truck! You do beautiful work.
I need to get some new tires for my Burb. These look and sound like just what I need.
Larry
Where exactly do you get them at?
After a month, still not missing the clop, clop, clop of the bias plys. :-D
Got them at Bud's in Murfreesboro, TN. Couldn't find them on the website but that doesn't mean they're not there.
Matthew 6:33
