| | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 27 | I recently installed a newly overhauled 235 engine into my '62 C10 Stepside. The SN's are only about 100 # apart. Anyway, here's what I did during the overhaul and subsequent installation: Took a '62 era 235 block, bored it .080 over, installed a "261" cam, "848" cylinder head, with Fenton Headers, an Offenhauser 2-2bbl intake, 2 Carter/Weber 2bbl carbs, and finally, a HEI ignition system. We also fitted the block with the flow through oiling system using 1/4 steel line and a remote, spin-on oil filter. The engine starts and runs fine and I am delighted with the tractability of the entire setup. Here's my question: upon start, the oil pressure quickly comes off the peg and climbs to about 25 psi. From there, it rarely wavers; at least at idle. When the engine is fully warmed, the pressure drops to about 20 psi and stays there regardless of engine speed. Should I be concerned with the lack of fluctuation? Is the system working correctly? Your thoughts?
'62 Chevy C10 Short Bed Step Side, 235 Six with Offy intake, 2 carter/weber 2bbls and Fenton headers. B-W T5 5 speed trans, with stock rear end.
| | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Is it the stock gauge and is it mechanical or elect, 20psi is survibable but it would be nice if around 35. Maybe the gauge in out of calibration??? Did you talk to the builder, did it get new cam bearings, what was the clearance on the rods/mains. Plumb in another mechanical gauge see if it reads better.
You Learn more Listening than Talking
| | | | | Joined: Oct 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 27 | Thanks for the input; I have tried another gauge with the same results. Another member has said that the lines I installed to the spin-on oil filter are too small. Ok, I think he's got it right so tomorrow we're going to install 3/8 lines...that's what is specified in the "inliners" forum. It suggests that I will see up to 60 psi at full throttle and around 30 at idle. I'd be totally over the moon with those numbers. So, I'll let you know. Bottom line is that this is a new motor with all the good stuff on it and it starts and runs like a top. I've got many smiles per mile with it! :-)!! Yea!!!
