5 members (baldeagle, Wayne67vert, klhansen, Joe H, Gray_Ghost), 92 guests, and 9 robots.
Topics128,019
Posts1,055,343
Members48,419
#944331 05/19/2013 3:41 PM
kwf
Offline
Any problem with using today's motor oil in an old truck? I know there is oil you can get for classic vehicles that still has Zinc in it. And what weight? Not trying to over think it but like my fuel posting question, just want to make sure I have no problems in the future. Truck is a '67 GMC w/305 V-6.
kwf #944339 05/19/2013 4:36 PM
I run Rotella 15-40 in all my trucks.
kwf #944364 05/19/2013 6:05 PM
kwf
Offline
Thanks alltruck72. You're the second person to recommend that. I had been thinking of 10W40 or maybe 20W50.
kwf #944376 05/19/2013 7:22 PM
10w30 oil with the SL classification in the circle on the container works just fine in my 235. Many oils designed for high mileage engines run the SL classification. I would not run 20w50, too thick
kwf #944396 05/19/2013 9:07 PM
kwf
Offline
Yeah, you're probably right. Never thought about a high mileage oil. The engine has 61,000 miles and the truck looks real good under the hood. In fact, it looks good everywhere.
kwf #944428 05/19/2013 10:29 PM
I'm running 15W40 Delo 400LE diesel oil in my stuff. Supposed to be a little better than Rotella; wouldn't guess it matters, though. I would bet money both superior to "high mileage" light duty oils, which would serve you no purpose, IMO. 61,000 is pretty much a new engine.
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
kwf #944535 05/20/2013 12:05 PM
J Online: Content
About any oil you like will work. Its been broke in for many years and I am sure the fellow before you didn't worry much about oil. New oils have changed, thats a fact, but a stock engine with some miles on it can use what ever brand you like. 10w30 - 10w40, straight weight 30, or synthetic 10w40, any will be just fine. 20w50 will be way to heavy and diesel oils stinks ! Rotella is the worst for odor, good oil, just stinks! I run 10w30 synthetic in my '70 250 L6.
Joe
kwf #944536 05/20/2013 12:11 PM
Don't they recommend straight 30 weight in the 216/235 engines for summer?? John
kwf #944557 05/20/2013 2:18 PM
Ex Hall Monitor
Ex Hall Monitor
Those recommendations were made long ago when oil wasn't as good as it is now and multi-vis wasn't even invented yet.
kwf #944752 05/21/2013 9:29 AM
I figured these engines don't run as tight a clearances on main and rod bearings as modern engines and need a heavier oil...
