7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59), 82 guests, and 3 robots.
Topics128,031
Posts1,055,435
Members48,422
#94431 01/25/2006 9:27 PM
Not sure if this is where I should post this or not, but here goes...
The '63 is coming into the garage in the next month or so to get a new (to me anyway) engine and probably a transmission rebuild. I got to thinking about something else while I was planning the shop time. Could I replace the original heater controls with something up to date (preferrably electric)? It doesn't have A/C, and I don't really care, but the heater/defroster doesn't put out very much and the controls can be difficult to move. Has anyone done this already? If so, did you end up with something that you liked or was it an abortion you wish you'd thought twice about?
Daily Driver 63 C-10 LWB Fleetside
Junior Member
Junior Member
Old Air products here in Ft Worth should be able to supply you with everything you need to refresh your current stuff. They sell nice new cables to replace your stiff current ones. Between new cables and rebuilding your stock controller, you should see much nicer results. They worked fine when they were brand new.
Tender caretaker of antique tractors and old trucks.
Tx, you got a link or contact info?
