Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Ridgeback, WICruiser, Joe H), 150 guests, and 7 robots.
Topics128,283
Posts1,058,513
Members48,490
#944291 05/19/2013 1:11 PM
Hello everyone, there is a engine on ebay that i am looking at. It is a 235 with block number 3764476 and head number 3836848. The stamped vin # is F0904A and the date code is E-25-9. He said they pulled it off a 60 station wagon, will this be a direct bolt on fit for my second series 55 truck with three speed trans without any modifications? Thanks.
matt55 #944307 05/19/2013 2:24 PM
Can you give the item number?
Only 1955 2nd through 1959 will have the needed front side mount provisions.
The E 25 9 makes it look like a march 1959 engine so it should work fine.
My Blog
matt55 #944314 05/19/2013 2:36 PM
3764476 is 1956 or later
3836848 is 1956 or later
That style of engine code started in 1957 - it indicates a regular 235 engine built in Flint, MI.
Would E 25 9 be May?
Give Dave the eBay item number to be sure.
matt55 #944320 05/19/2013 2:44 PM
Don't know what I was thinking.
May is correct.
Thanks for catching that!
My Blog
matt55 #944329 05/19/2013 3:37 PM
Item number is 171037430402 So this should fit without any issues? Thanks for the replies.
matt55 #944335 05/19/2013 4:01 PM
That engine will be a direct fit!
You will need to use your truck bellhousing though.
My Blog
matt55 #944348 05/19/2013 4:51 PM
Thanks Dave and tclederman.
