8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Hello everyone, there is a engine on ebay that i am looking at. It is a 235 with block number 3764476 and head number 3836848. The stamped vin # is F0904A and the date code is E-25-9. He said they pulled it off a 60 station wagon, will this be a direct bolt on fit for my second series 55 truck with three speed trans without any modifications? Thanks. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Can you give the item number? Only 1955 2nd through 1959 will have the needed front side mount provisions. The E 25 9 makes it look like a march 1959 engine so it should work fine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 3764476 is 1956 or later 3836848 is 1956 or later
That style of engine code started in 1957 - it indicates a regular 235 engine built in Flint, MI.
Would E 25 9 be May?
Give Dave the eBay item number to be sure.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Don't know what I was thinking. May is correct. Thanks for catching that!
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Item number is 171037430402 So this should fit without any issues? Thanks for the replies. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That engine will be a direct fit! You will need to use your truck bellhousing though.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Thanks Dave and tclederman. | | |
