12 members (FAST55, 1955 1 Series, GusG, sron48, Wally / Montana, Stovebolt48, JW51, GrandpasJimmy, tclederman, ‘37ChevyPU, Wayne67vert, 1 invisible),
66
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Hi Everyone - New Denver Stovebolter here. This site is great and the people are fantastic. This is my first post and question as I have already gotten many answers from past discussions. Hope I am not violating any introductory protocols.
The clutch and brake pedals in my 52 truck have about 1/8"-5/32" side play in them at the top of the pedals. I've read about the challenges of replacing the bushings due to them being too thick for the shaft so I wanted to know if this much play is acceptable? It feels like a bit much but I have nothing to compare it to. Since I've got it stripped down to the frame ready to sandblast I wanted to make this determination first. Thank you for any advise you have or telling me if this is in the wrong forum.
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you are going that far now is the time to replace them. Its been a long time since I have done one but it shouldn't be a problem. If it just needs a little you can hone it out with a brake cyl. hone. If you are replaceing the pin you can grind notches in the end of the old one & use it for a reamer. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Thanks Wrenchbender. Some things are just easier to do while you are already there and I guess this is one of them.....
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Not sure if that kind of play is acceptible but none the less I replaced mine.
I bought my new bushings from Jim Carter and had no problem at all replacing them. Found a socket in the tool box and drove out the old ones and then froze the new ones and then drove the new ones right back in. No need to ream the new ones to fit the shaft just lightly coated with bearing grease on they went right back on. I would go ahead and do it now while you are thinking about it.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Thanks TrknGMC. I just got new ones and they are definitely a tighter fit so this should take care of it.
