| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Anybody know of a place that can rebuild an an old low pressure oil pressure gauge and turn it into a higher pressure one. This is a 41-46 gauge.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It would probably be easier to find a GMC gauge. | | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | Jim carter sells the complete cluster.
http://www.oldchevytrucks.com/cart/product.asp?prodid=RESP230&i=10696||||| | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks, I have several clusters and assorted parts, and would like to avoid buying an entire new set up if possible. I didn't realize there was a GMC option.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | there are places, but they are horribly expensive. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I just got a quote for oil pressure gauge upgrade, about $150. A little more than I expected.
