4 members (Ricks Big Dump, Donf, Peggy M, 1 invisible), 148 guests, and 3 robots.
Topics128,086
Posts1,056,101
Members48,434
#943847 05/17/2013 1:35 PM
So... About 4 months ago I replaced my master cylinder on my 1950 3600. No problems.. Recently while doing some routine maintenance, I noticed it leaking at the large nut on end that goes to the brake line. It was leaking between the nut and the master cylinder. There is a copper washer between. I used a wrench and tigheten it up a bit (about 1/4 turn) We'll see if that works. IF not, it is going back to Jim Carter.
I suspect it will be fine..
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Riding in the Passing Lane
If you turned it very much like 1/4 turn that will fix it.
1972 Chevy c10 Cheyenne Super
Thanks. I drove it a bunch today around town and no leaky..
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
If it is a banjo type of bolt, it helps if the washers are new or used once only.
Hi Mark. No, it's the large bolt (1 1/2 inch or more??) on the end where the brake line goes in.. It looks like a large reducing bushing. So far, it's doing fine.
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
FYI, copper washers can be annealed and reused.
My Blog
Hey Dave. thanks. you know I was just taking to someone on that and what they do is to heat the washer/s up (annealed) with a flame (doesn't take much) then re-use it.
I learned something....
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
