| | | Forums66 Topics128,109 Posts1,056,271 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | So... About 4 months ago I replaced my master cylinder on my 1950 3600. No problems.. Recently while doing some routine maintenance, I noticed it leaking at the large nut on end that goes to the brake line. It was leaking between the nut and the master cylinder. There is a copper washer between. I used a wrench and tigheten it up a bit (about 1/4 turn) We'll see if that works. IF not, it is going back to Jim Carter.
I suspect it will be fine..
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you turned it very much like 1/4 turn that will fix it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thanks. I drove it a bunch today around town and no leaky..
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | If it is a banjo type of bolt, it helps if the washers are new or used once only. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Hi Mark. No, it's the large bolt (1 1/2 inch or more??) on the end where the brake line goes in.. It looks like a large reducing bushing. So far, it's doing fine. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | FYI, copper washers can be annealed and reused.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Hey Dave. thanks. you know I was just taking to someone on that and what they do is to heat the washer/s up (annealed) with a flame (doesn't take much) then re-use it.
I learned something....
