2 members (Napco Man, GrandpasJimmy), 78 guests, and 1 robot.
Topics128,095
Posts1,056,067
Members48,433
#943953 05/17/2013 11:16 PM
What is the purpose of the small plug located toward the top of the U joint housing on the back of a Munci 4 speed trany?
You might be referring to the hole through which the factory put in the gear oil after assembly. On some of the the SM420s, instead of a plug there is a grease nipple that serves to further confuse people (the gear oil was "injected" through that nipple). That hole/nipple is not normally used by us mortals (if I am wrong, we will hear about it).
Initial factory fill?
That's what I was told.
That's what I was told by people on this discussion board. I must be true?
Thanks for the help. As I think about it, your answer makes sense from a prosses point of view.
