| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | Rochester 1958 carb rebuilt last summer ran fine, ran fine this summer.Got on high way for 50 miles drove fine at difrent speeds,got off high way died out at idal.The idal was very low picked up idal to normal runs fine.What is the cause of my low idal problem, it ran that way for a year no problem.Any ideas what is going on.Thanks
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would check distributor point gap first. Points with too close of an opening will work OK with a little RPMs, as they seem to bounce or are thrown some, and fail at idle. Over time as the rubbing block wears the points close up. I'm not saying it is not carb, just that I have seen just what I described.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | X2 small gap, sticky distributor, in block for vaccum advance.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
