6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
#943873 05/17/2013 4:19 PM
What protected the wire from the frame to the tail light(s) on the 1/2 ton pickup trucks? Were they left exposed or did they have a cover? If covered with what? Thanks
they were covered with a fabric like material. It is available at any of the truck vendors like Jim Carters or Chevs of the 40s.
Thank you. I have some. I guess you just tape the open end.
I believe there was originally a special rubber grommet/sleeve on the light end that was held with a crimped metal ring
Thanks. Humm maybe silicon and a nice ring would be close.
