| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Hi All, Just a quick question,,,,is the starter for a manual trans. 54 car, the same as a starter for a powerglide? Im fixing a friends car,,he dont know, i dont know. Thanks in advance,,, Marty | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 1954 parts book is showing them as a replacement as being interchangeable but my 61 books has them separated. The Power Glide starter has four field coils and the stick has two from the factory. It is a mystery why the early parts books would do this as the two field starter is a little weak to turn over the Power Glide setup. The tag on the starter will tell which one it is. 1107075 Stick 1108035 Auto
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Thank-you Tim and Dave. Guess i shouldnt be so lazy and look it up in the manuals as you did. | | |
