1 members (Guitplayer),
104
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | I have 49 Chevy pick up and I been looking at upper hood latch and they're different then what was in there. I'm not sure if it's the right one, can anyone tell me if they will work or where to get one.? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Are you referring to THIS or the safety catch? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 |
Ed
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I discovered that the lower piece as shown here that is attached to the radiator frame had suffered repeated impact damage from the hood safety latch. It so happened to be missing the spring that caused the hook to slam down when the hood was closed. Instead of buying a whole new piece for $250.00 I was given some straight spring wire and made one so now things function. Just thought I would share that in case others find the same problem.
I don't see why we should judge someone who is looking for help and requests an email address, I have done the same and others have helped me out. Go easy on people life is too short. If that rule is carved in stone it should be changed.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | Yes forty9 where do you buy the whole piece at
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Place an ad in the swap meet Truck Parts Wanted section. Maybe someone on this board has one or two. | | |
