| | | Forums66 Topics128,164 Posts1,057,076 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 66 | This thread has been moved.<br /><br />Errol, you'll be better served in the BIG Bolt Forum so I moved it to there. I may as well say it before the other guys does....it will help if you have the Vin#. There is actually a decoder here on the bolt in the tech tips section. Take your time, learn your way around here....there is just SOOOO much here its hard to comprehend. The guys will help you though. | | |
