0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Sometime ago there was a post here regarding a 6 volt Battery Jump-Starter. I mentioned that I had one and a person you frequents here very often in so many words said I was lying. At that time I could not find it to take a pic. Well, today I found it tucked away under my work bench. See the pic... Link to unit...
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That looks very handy.
Does LectricLimited (Battery Butler) still sell either the 6v or the 12v Battery Jump Starter?
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | I don't know if they still make the jump-starters or not. The link I gave was on the box.
I only used that thing one time (worked Ok) I installed a optima battery shortly after I got the unit (about 7 years ago) and have had no use for it. | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Thanks for sharing the info. I called Lectric Limited, Inc. this a.m. They no longer carry this unit. BUMMER! | | |
