1 members (baldeagle), 91 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#943040 05/13/2013 11:53 PM
I'm getting ready to go get some dirt in my 46 COE. I'm wondering how much weight the bed can lift. I don't know the style of bed I have. Has new seals and a new high pressure hose. Here is a poor picture of what I have. I thinking about getting 4 or 5k lbs.
http://s1275.photobucket.com/user/jrpontiac/media/DSCN0006_zpsee7b5cb8.jpg.html?sort=3&o=7
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Have you put anything back there yet to test the ram? Whats the truck rated at? If it doesn't dump you'll just have to shovel untill it does?
it should lift what ever you can put it that bed you made and then some. what is the gvw of your truck? then go get it weighed empty and the difference is what you can legally haul. my two ton dump can legally 4.5 tons. when i hit four tons i hear the hoist growning until i get past the fulcrum of the lift. with 3 tons or less it flys right up. mine is a galion hoist.
All I can tell from your photos is that it is a twin arm underbody. If you'll measure the cylinder diameter and length so you can approximate the stroke and give me the body length I can give you the mfgr's. rating.
Be sure those lift arms are in good condition and fittings adequately greased before attempting to use it. And if you have any info on the pump it is somewhat helpful.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
