1 members (baldeagle),
53
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Have you put anything back there yet to test the ram? Whats the truck rated at? If it doesn't dump you'll just have to shovel untill it does? | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | it should lift what ever you can put it that bed you made and then some. what is the gvw of your truck? then go get it weighed empty and the difference is what you can legally haul. my two ton dump can legally 4.5 tons. when i hit four tons i hear the hoist growning until i get past the fulcrum of the lift. with 3 tons or less it flys right up. mine is a galion hoist. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | All I can tell from your photos is that it is a twin arm underbody. If you'll measure the cylinder diameter and length so you can approximate the stroke and give me the body length I can give you the mfgr's. rating.
Be sure those lift arms are in good condition and fittings adequately greased before attempting to use it. And if you have any info on the pump it is somewhat helpful. | | |
