Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
V
V Offline
Checked the cable connected at the tranny, spins freely in the cab. When connected to the speedo it may go to say 30, stops at that point, and not proceed to 40 smoothly, same when hitting 40. Odometer doesn't work at all. Blew some graphite in , still nothing.It is a 1957 3200/3 speed , column shifter.Seems like the issue is in the speedometer.Looking for input, thank you all for your input.
'57 3200
yes, the issue is inside the speedo, there's a plastic worm gear that drives the odometer that's stripped, time to pull it apart and rebuild it, this tech tip might help
