| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I replaced the upper mast bearing in my '46 last night and it went well until I went to put the horn button back on. At each step, I would hook up the battery to make sure there were no shorts. When I put the horn button on, no matter what I tried, the horn would blast. When I took it apart, the spring sent things flying and I wonder if there is supposed to be some sort of insulator between the spring and the button. Any advice would be most welcome. Thanks. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | The position of the column in steering gear box can affect this. The cast piece under the steering wheel has to be free to move. Hard to explain. The center steering column is the negative return. The piece with the wire must be connected to positive and not touch ground. | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | Thanks. I was wondering about that. I'll check it out this morning.
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I pulled the steering wheel back off and sure enough, the mast jacket was too high up. A few taps and it now functions. Thanks again GWWirth.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I am glad that worked. I had the same issue. | | |
