1 members (VicZ),
231
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I can't find the same needle as I found on my speedometer, which is broken for no apparent reason. Broken Speedometer Needle 1. Has anyone seen this needle style before and know when I can purchase one? I can't find one like it. 2. Has anyone ever tried to repair a needle? This one has a "hollow" on the back and I think I could use some krazy glue and bond a wire in the back as a splice. Not sure if the additional weight of the splice would affect the movement / calibration of the needle. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I haven't done it, but might be worth a try. You won't know if it affects accuracy until you make the repair. The center "bullet" will hide the repair. Otherwise, a needle from a donor '54 speedo may be the only source for a replacement Be careful when you remove the base of the needle from the shaft. The shaft is brittle. Dab some penetrating oil where the shaft enters the base and let it sit for a while. The needle pulls straight off - not threaded. Here's what happens if the shaft breaks. I don't know an easy fix for a broken shaft. Luckily, this happened while I was pulling a broken needle off of a spare speedo that I was using to learn before disassembling the speedo in my '54. It snapped without warning. > Broken shaft in needle base- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | I would expect weight could be a factor, don't really know. Maybe go find a piece of guitar string, small and strong to glue in. Any guitar store would have pieces of trimmings. | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I was thinking a very small gauge aluminum strand would work as well. I'll try it if I can get the needle off the shaft. I may have to glue it with the needle still on the shaft because that needle feels really stiff on the shaft and I dont want to break it as Lonnie shows. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | A sewing needle may work for a splint. Experiment with adhesives. Extra weight near the center probably won't affect the speedo. The break may be visable though the odometer window. But the needle is thin and painted flat black at that end, so it will disappear against the odo numbers. I'm sure that other 'Bolters have had the same problem. Perhaps they can add some experienced advice. I'm sure that all will be interested in your fix. Don't know if you are going to reface your gauges - > Here is a thread of how I did mine> Slide show> Album- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | I tried to fix one that way using a piece of a toothpick and super glue. Didn't work. The extra weight, even though negligible, was enough to mess it up. | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | Lonnie
Even with your warning, I still broke the shaft. Darn things are really fragile. Guess I'm now in the market for a donor speedometer. One step forward; one step back. I guess that's part of the experience.... | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | RATS! Doubt if there was anything that you could have done to prevent the break. Maybe you should poke around in the back room of Richie Hardware to find something that you can jury rig into a new shaft. (Doncha wish you could!)
Keep forging ahead. You have a good looking truck and a fine family tradition to uphold.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I could not find the replacement needle stem and broke down and purchased a new speedometer that I will put in the old housing.
Do I leave the mileage at 000000 or turn it up to the mileage of the prior speedometer (about 54,000), which may not be entirely accurate either? | | |
