| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | I am looking at some rims that came off a 2005 Chevy Colorado - 16 inch 5.5 6 lug pattern.
DOes anyone know if these would fit my 1953 3100? | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | try them on for a test fit  if they work then when my 2012 canyon is worn out ill put them on my next project truck. or i'll just put my project truck on the canyon frame  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No, they will not work. The Colorado uses a positive offset wheel, with the mounting surface almost all the way to the outside of the wheel. They will not clear the tie rods or steering arms.
Bill Burmeister | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | they wont fit, the backspace on the rims is too much, they will rub the rear springs on the back and hit the tie rods on the front | | |
