| | | Forums66 Topics128,052 Posts1,055,770 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94221 01/07/2006 8:13 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Im trying to fix my signals. The drivers side works but when I try the passenger side they come on but they dont blink. | | |
#94222 01/07/2006 10:06 PM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | had a similar problem on my 61. after spending two weeks testing all of the wires and fixing some really poorly done wiring repairs i discovered the real problem. i ended up doing two things to fix this problem. the first thing that i did was switch the grounding clips that the mounting screws hold the tailight assemblies on the truck with. i also took a piece of sandpaper and sanded all of the parts of the tailight assembly that need to make contact, i sanded them until they were good and shiney. my tailights are brighter and now they also work under all signal settings. makes me want to do the same thing for my really dull headlight beams, just to se if it works.
also i would check the turn signal flasher that is mounted on the fuse block. another thing that i did but forgot until now was change the little relay box on the steering column, not the signal itself but the little relay that turns the mechanical signal input into an actual electrical signal.
I ended up doing a lot of work and changing but what really fixed things was the new grounding clips and the cleaning of all contact surfaces in the tailight assembly.
good luck friend and may the electrical gods smile on you while you zap and twist your way to a happy truck.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
