1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#942209 05/10/2013 12:22 PM
Y
Y Offline
I'm bench starting a 235 out of 59 car. I did get it to fire and run for about a minute. Now it will fire but just won't continue to run. Is there quick/simple way to check the cam gear?
Phil
I think if it will run for a minute it's not the cam gear...
The cam gear won't stretch like chains do.
Give me ambiguity
or give me something else
In my experience the cam gear is either good or bad. Sometimes the old fiber gears lose some teeth. When this happens the engine will not run at all. You could likely remove the cam gear as suspect because your engine runs.
If you have to check it... The timing cover will need to be removed. You will first have to remove the harmonic ballancer, and will likely have to remove the oil pan as well.
Runs and stops are usually fuel delivery/ carb problems.
