| | | Forums66 Topics128,079 Posts1,056,303 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Just today my parking brake will not engage here is a quick video of whats going on. ...video... ...quick time... I checked the bracket fasteners and noting is loose. would like some ideas on what to look for. dose the release bar ever need to be filed or dressed? thanks for any ideas | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | There is a coil spring behind the piece that goes around the pedal rod. Looks like that spring is broken and not pushing the lock into place.
Looks like it is laying almost flat on the floor. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Is the release lever hung up? I beleive there might be some adjustment on the release handle? Try turning the handle some and push in to make sure it is not stuck.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Ill look at the spring and lever after work today. I should of pulled back the mat and jute padding last night.
The rod has powercoating and has been working great since I reinstalled everything 3 years ago.
just not sure why it quit grabbing all of a sudden
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Slight adjustment in the release lever at the pull is all it took. The brake knob has a jam nut that spun down a bit. Just a half a thread is all it took. Thanks for the clues. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Glad it worked out! I had to do the same exact thing. Looking forward to your next video!
