| | | Forums66 Topics128,081 Posts1,056,074 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 8 New Guy | | New Guy Joined: Jun 2012 Posts: 8 | Greetings:
I have a 1959 Viking 50 LCF with a bad drag link. From searching this forum I believe that the part is 3729933 "Steering Connecting Rod". Are there any sources for this part or does any one know part numbers for building one from tie rod ends or drag link ends from more current medium duty trucks?
Thanks, Randy | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Chances are one needs to look under '55-'59 similar GM trucks to find a good one. Or, don't know what the configuration is(px), one could find one too long and cut it off, re-thread it if that would do.
| | | | | Joined: Jun 2012 Posts: 8 New Guy | | New Guy Joined: Jun 2012 Posts: 8 | Not very many old big trucks around my area. In fact, I have the only one I have seen in about 10 years. I was pretty much thinking I would have to make one. The steering box is is forward of the axle with the drag link extending to just in front of the axle with the wheels straight. The pitman moves fore and aft. Looks to be about 17.5 inches center to center and is a straight bar. Looks like the 1 ton, just longer. Just have the measure the big and small end of the tapers and see what I can find.
Thanks, Randy | | | | | Joined: Jan 2013 Posts: 8 New Guy | | New Guy Joined: Jan 2013 Posts: 8 | I also have a 1959 Viking 50 LCF. I am also in need of this part with no luck so far. Have not been able to cross GM number to any other jobber. Please let me know if you find something and I will do the same.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I believe you are looking for the following part... Steering Connecting Rod Assembly 55-59 Ser. 5 (exc. P/S) w/ stud (5/32 dia. hole in thd. end) 3729933. Hope this helps... Mike B  | | | | | Joined: Jun 2012 Posts: 8 New Guy | | New Guy Joined: Jun 2012 Posts: 8 | Right. That's the part I have been unable to find. Guess I'll take it apart this weekend and start measuring to see what I can come up with.
Thanks, Randy | | | | | Joined: Jun 2012 Posts: 8 New Guy | | New Guy Joined: Jun 2012 Posts: 8 | I contacted Rare Parts and am sending my drag link to them for replacement if they can match it up or repair if not. Will let you know how it works out.
Randy | | | | | Joined: Jun 2012 Posts: 8 New Guy | | New Guy Joined: Jun 2012 Posts: 8 | My new drag link is on the way. They were unable to match it, so they built a new one. It should be here this weekend.
Randy | | | | | Joined: Jun 2012 Posts: 8 New Guy | | New Guy Joined: Jun 2012 Posts: 8 | I have the new drag link loosely installed. It will work fine.
Drag link: http://www.flickr.com/photos/97645082@N08/9058817497/
Truck http://www.flickr.com/photos/97645082@N08/9061026572/
Truck after a bit of wax http://www.flickr.com/photos/97645082@N08/9058806385/
Grain box removed http://www.flickr.com/photos/97645082@N08/9058820417/
Randy | | |
