| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I have installed my wiper motor in my 49 chev. When the linkage is unhooked it runs fine. When I hook up the linkage the wipers push down towards windshield frame and it locks up. Could the arms on the wiper arm spindles be upside down? Iv'e run out of ideas. Thank you. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | where is the new motor from?
is it electric? vacuum? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You might need to remove the blade arms an re-position them. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | The wiper motor was rebuilt by Ficken the wiper man. I have had the wiper arms off and the spindles turn, Then I shut the wiper off and let it park, Then reinstall arms, And it does the same thing and locks up.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I don't know if this is your problem but when I replaced my vacuum wiper motor with an electric one from LMC, I also got a linkage problem that I couldn't correct with blade positioning. I can't remember the symptoms exactly but it seemed that one arm was too short. See the picture. I cut a piece of metal and put 4 slotted holes in it for adjustability. I then got brave and cut the arm and put round holes in it. Turns out that lengthening that arm solved the problem. - Adjustable wiper arm. - - 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Make sure the transmissions arms are on the correct post. Denny as always has some excellent pics. ...link... I had a problem with the passenger side binding. I had the arms on the wrong post. On the electric version you can adjust the park. Not sure about yours Good luck | | |
