2 members (Stovebolt48, 1 invisible), 131 guests, and 2 robots.
Topics128,211
Posts1,057,473
Members48,473
' Offline
What's the best way to clean this old GM nos Distributor Gear ?
Engine: Early 1954 235 6-cyl. with small cam journals Forged Steel camshaft.
So, the distributor gear is hardened steel to match the cam.
See: PIC
http://i669.photobucket.com/albums/vv57/glp0329/DistributorDriveGearGMNOS_zpsfb522666.jpg
I'd like to use this nos gear but don't want to hurt the fit on the distributor shaft.
Any suggestions appreciated.
Thank You,
George
1954 3600
Now cruising in
The Passing Lane
It looks like a protective coating more than rust. I would soak it in lacquer thinner than scrub with a brush and see how it comes out.
My Blog
Soda blast it.
its cosmoline, if the lacquer thinner doesnt work try boiling it off in water. it only a wax protective coating.
If its hardened steel, why not clean it up on a wire wheel on a bench grinder - or as I call it, "small parts slinger".
