Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Gdads51, Stewart2, Otto Skorzeny, 1 invisible), 85 guests, and 1 robot.
Topics128,292
Posts1,058,598
Members48,492
Can you help me identify what seats work in the 60-66 Chevrolet suburban and which ones fit in a 60-66 GMC suburban? I have a couple of seats thatI am in the process of selling and I have some confusion on which ones fit in which make. I had a guy come by in his 60 Chevrolet suburban and tell me they were not the correct ones and another guy come by in his 64 GMC suburban and we could not make them line up either. I know they came from a 60's suburban, I just don't remember which make or year, I pulled them myself. They have the tube support with holes that had the flat bolt and wingnut to hold them to the floor.
I thought that these came from an early GMC suburban, which to my understanding would fit both the Chevrolet and the GMC, is that correct?
If you have pictures that show the difference, I would truly be grateful. Thanks..................g
The wider of the two seats goes in the far back.
The shorter goes in the middle if there is a rear (3rd seat)
The wider comes forward if there is only a front and back seat.
The shorter seat allows you to get into the 3rd row seat.
Think that's correct. What do you have to sell??
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
You are correct in the way they line up. What I need to know is what seat fits in which suburban? They made two styles, one was similar to the 1947/59 seats as they mounted to the floor via slots and the GMC seats were mounted on a track. I want to see the difference between to two so I can identify what I have.
I will post an ad in the swap meet after I can get a positive identification on what I have
These are similar to what I have these are neals49 seats.
Early years used the same seats IIRC, but 63-66 or so GMC used a track setup which was somewhat different from the Chevy seats. I think thats how it goes.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
That's my thought too, I need pictures of the differences. Thanks
George,
My Dads 62 GMC Subn,bought new at Cassel GMC in Patchogue NY,had all the seats in it.
The seats were held to the floor with what looked like flathead carriage bolts,up thru a tubular frame in 4 spots to coincide with slots in the floor,topped off with a square washer,concave on the bottom and flat ontop and finished off with a wing nut.
You could interchange the 2nd /3rd seat location with each other.
I still have the 2nd seat up on a shelf in my garage.
Sadly the 3rd seat was given away back in the late sixties,cause it was taking up space.
And it was only used once or twice.
Believe it or not,except for the upholstery,it looks identical to the 2nd seat in my 51 chevy subn.
hope this helps.
regards steve sr.
Thanks Steve, that is what I thought. The 1960/66 Chevrolet and the 1960/62 GMC used the same seats, the change came in 1963 for the GMC which used a track system.
I would like to see the seat mount s for both types. I have what I believe to be Chevrolet and early GMC, but was told they did not fit the chevrolet. Anyone have any pictures of the seats mounted that show how? Thanks
Jon S
Las Vegas NV
I can't see the base or supports and that's the only difference between Chevy and GMC. Thanks........g
Jon S
Thats 1963 or OLDER Just looking quick cause of the wrap around windshield and Dog leg doors.
Also Definately a GMC cause of the dash.
Chevy 63 and down had a 'double hump dash'
regards,
steve sr.
P.S.
Would love to see the lower shot of those seats as what George is talkin about!!!
there is a good thread about this on the67-72 site and shows the differences on mounting
ron
http://67-72chevytrucks.com/vboard/showthread.php?t=493957&highlight=suburban+seats
Thanks, padresag. That has a lot of information and it helps a lot. I wish I had a comparison of the two different styles upside down so I can see the differences. I think mine are the bolt down style. i had a guy look at it for his Chevrolet and he said it wouldn't fit, I mounted it in a GMC with tracks and it wouldn't fit that one either. My guess is that it is for the Chevrolet and the first guy did not know how to mount it.
I sent one of the "sellers' that knows a lot on these a PM, but he never answered me, so I do appreciate those that take the time to answer not just sell there stuff on here.
Thank you Steve sr, Jon s, 64fleetside, and padresag for taking the time to help me out! thumbs_up
full set on ebay today
I have a few early ('60-'62) GMC Suburbans and they have the tracks. All of my Chevy Suburbans, have the oval plates mortised into the floor, with the elevator bolts, for mounting. The later GMC Suburbans, I have, also have this configuration. I will see if I can come up with some photos of the bottoms of both style seats, as you mentioned, in order to determine the differences.
Thanks, I am sure others will appreciate the information too.
I know this might be a little late, but are you still looking for pictures of the seat mounts?
Sir Searchalot
Sir Searchalot
G-Mo, My stock 66 GMC Carryall had tracks to mount the seats with some flexibility front to back. The track is a "C" channel with the open at topside. The fasteners are parallelograms about 1/8 thick with a stud sticking up and thru the hole in seat frame, the a curved washer and wing not. When the nut is tightened the parallelogram rotates and locks into the "C" channel. Chevy's have the keyhole. Maybe you have this info already?
Channel here:
and here:
Here:
[IMG]http://i279.photobucket.com/albums/kk158/bartamos/KGrHqEOKpgE7F5Wqi35BRet-g4TrQ60_3.jpg[/IMG]
The GMC has two mounting rails and the Chevy has three sets of keyholes. Not sure if one fits the other or not.
Ken
Sir Searchalot
Sir Searchalot
I believe those that say 60-62 GMC had bolt in rear seats, 63-66 had the tracks may be correct.
[IMG]http://i279.photobucket.com/albums/kk158/bartamos/image3.jpg[/IMG]
[IMG]http://i279.photobucket.com/albums/kk158/bartamos/image2.jpg[/IMG]
[IMG]http://i279.photobucket.com/albums/kk158/bartamos/DSC03484.jpg.hyml[/IMG]
[IMG]http://i279.photobucket.com/albums/kk158/bartamos/130440_400.jpg[/IMG]
[IMG]http://i279.photobucket.com/albums/kk158/bartamos/145630.jpg[/IMG]
[IMG]http://i279.photobucket.com/albums/kk158/bartamos/jantzen_jim_1963_03.jpg[/IMG]
Above are 1963-1966
Here is a 1960 GMC floor with key holes.
http://i234.photobucket.com/albums/ee278/Corts76/SDC16284.jpg
Lots of confusion about this. If Tony has "later GMC's" with key hole. I definitely had a 3 year old 1966 GMC Carryall with tracks. Did we catch Chevy and GMC swapping left over rear bodies with appropriate front clips, horn button, etc? Yes, they did have keyhole GMC's and Track GMC's, same year.
Thanks for the links. What I was looking for was the actual seat bottoms. The mounting pieces that attach to the floor. I would like a side by side comparison if possible or two pictures one of each style viewing from the floor up. I can see how they bolt to the floor, but I can't see the frames themselves. Thanks.............g
Sir Searchalot
Sir Searchalot
