| | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | I converted 6 volt positive ground to 12 volt neg ground. Question is do you still use same points and condenser, or do they have to be changed. Any help here? | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy jetmech6868, I think the points will be fine, and I think the condensors may have the same part numbers six volt and twelve volt, you should reverse the polarity of the coil as well. I'll do some research on condensors and get back to you. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy jetmech6868, yes I remembered correctly the points and condensors are the same six and twelve volt, hope that helps. | | |
