4 members (Tim Canfield, Bill Hanlon, Hotrod Lincoln, 55shaker), 108 guests, and 4 robots.
Topics128,195
Posts1,057,380
Members48,469
#940870 05/04/2013 8:04 PM
I converted 6 volt positive ground to 12 volt neg ground. Question is do you still use same points and condenser, or do they have to be changed. Any help here?
3B Online: Content
3 Online: Content
Hy jetmech6868, I think the points will be fine, and I think the condensors may have the same part numbers six volt and twelve volt, you should reverse the polarity of the coil as well. I'll do some research on condensors and get back to you.
3B Online: Content
3 Online: Content
Hy jetmech6868, yes I remembered correctly the points and condensors are the same six and twelve volt, hope that helps.
