3 members (Nick in Manitou, Hotrod Lincoln, TUTS 59), 123 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
1 Offline
I have been all over the internet and can't find anything close to iding these numbers that are on my block CAA203273 are what I see on the id plate near the distributor.
Does not look like any numbers I have seen. Could the be California Assigned numbers on a replacement engine? What are the casting numbers on the engine block?
CAA203273
Might be a WWII code
2AA in 1942 decodes to:
2 = 1942
A = passenger car
A = 216 Flint, MI
DAA in 1946 decodes to:
D = 1946
A = passenger car
A = regular engine, Flint, MI
1 Offline
So I'm guessing if that's what it is, they took the original motor out that it had in 41 and put a straight 6 from 1943 in the dump truck??
1 Offline
On the other side of the block it says 25 there's Like an inch gab and then it had 849
Post the various codes at the locations shown here. The codes should be in similar locations on your engine?
1 Offline
Yes they did help out a lot. They were pretty close. The markings by the fuel pump on mine were to the right and bottom but and for the 41 head all the numbers are under the cover. But yeah those pictures d-codes really helped out. found out that the head is from May 18 1941 and the block is from June 1 1943.
