1 members (baldeagle),
53
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94066 12/28/2005 1:58 AM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | May sound silly but does anyone know if I can hook up just a battery to the starter and tranny to turn the motor over. I currently have not a single wire hooked up because I have no cab or any other sheet metal. Thanks in advance for all your help and sorry this is similar to a previous post I had. Brian
1946 1/2 ton I'm not addicted I just don't know when to stop
#94067 12/28/2005 2:28 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you just want to spin the engine all you need is battery pos. to the starter terminal and neg. to someplace on the engine or trans. If you want to start it you need a wire from the starter terminal to the coil also. | | |
