3 members (Bill Hanlon, Lightholder's Dad, baldeagle), 38 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#94066 12/28/2005 1:58 AM
May sound silly but does anyone know if I can hook up just a battery to the starter and tranny to turn the motor over. I currently have not a single wire hooked up because I have no cab or any other sheet metal.
Thanks in advance for all your help and sorry this is similar to a previous post I had.
Brian
1946 1/2 ton
I'm not addicted I just don't know when to stop
#94067 12/28/2005 2:28 AM
If you just want to spin the engine all you need is battery pos. to the starter terminal and neg. to someplace on the engine or trans. If you want to start it you need a wire from the starter terminal to the coil also.
