9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck),
59
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | Hi Stovebolter's two questions.
1- After I purchased the 3100 I had to replace the headlight switch. Is it normal for the park lights to turn off when I turn my headlights on? Park light work fine when switch is in park (half pull) position?
2- Is it normal for my high beam indicator to come on when I turn on my headlights for (low beam)? The high beam indicator brightness increases when I switch to the high beams.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hi DJRoy - 1 - Yep. That's the way headlights and park lights worked in 1950. Headlights and park lights do not burn at the same time. 2 - Are you sure that the high beam indicator is burning when the lights are on Low or on Park? The outside of the bulb or the lens may be illuminated by the lamps in the speedo cluster and look like the bulb is burning dimly. (That's what happens in my '54). Remove the socket from the speedo housing. Clip a ground wire to it and see if it comes on with the park lights or the low beam headlights. Better yet, check it with a VOM. > [CLICK] Recent discussion about high beam indicator problemGood luck, - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Lonnie is right on about the high beam indicator. You can see the interior of the speedometer here - http://rustyfiftyone.com/gremlin-hunting/ - there is a tube around the high beam bulb to isolate the light. If the gauge face doesn't sit flat, which it never does, light from the speedometer illumination will make it seem to light up. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lonnie is, of course, also correct regarding the parking lamp light.
Headlights are used when you are driving. Parking lamps are used when you are parking/standing.
In the "old days", it was illegal to drive with parking lamps on.
