1 members (Gray_Ghost),
77
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi all, I have 58. 3600 with a 235. Problem is when idling its sounds fine. If I push the gas quickly the idle drops as if to gasp. If I give it gas slowly, idle increases nicely. I am sure this is just an adjustment. And I think it involves the gas and air/vacuum. Can anyone give me more details Thanks Rick
Rick 58 3600 4 on the floor
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Rick,
How did you adjust the timing (what procedure)?
How did you adjust the carburetor (what procedure)?
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Gosh you got me there, timing I did a couple of years ago. I recall taking cap off and adjusting the screw. As for the Carb - I have never done adjusted it
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Might be the accelerator pump in the carb. When you look down the carb throat you should see a good stream shoot into the manifold when you push the gas pedal. If not you may need to rebuild that carb. Easy to check before you start adjusting things.
Ed
