1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#939915 04/30/2013 9:42 PM
Hi all, I have 58. 3600 with a 235. Problem is when idling its sounds fine. If I push the gas quickly the idle drops as if to gasp. If I give it gas slowly, idle increases nicely. I am sure this is just an adjustment. And I think it involves the gas and air/vacuum. Can anyone give me more details
Thanks Rick
Rick
58 3600 4 on the floor
rickyt #939918 04/30/2013 9:48 PM
Rick,
How did you adjust the timing (what procedure)?
How did you adjust the carburetor (what procedure)?
rickyt #939921 04/30/2013 9:58 PM
Gosh you got me there, timing I did a couple of years ago. I recall taking cap off and adjusting the screw. As for the Carb - I have never done adjusted it
Rick
rickyt #940039 05/01/2013 10:56 AM
Might be the accelerator pump in the carb. When you look down the carb throat you should see a good stream shoot into the manifold when you push the gas pedal. If not you may need to rebuild that carb. Easy to check before you start adjusting things.
Ed
