| | | Forums66 Topics128,093 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 23 New Guy | | New Guy Joined: Jun 2012 Posts: 23 | I have a 1950 4100. I konw it was stock without turn signals and only one tail light. when I got the truck the turn signals where already mounted on the fenders so Im not going to remove them. I have all the lights working,front and rear turns and parking stop lights. My question is can I get original equipment lights that have the daul fillement bulb? The one that came on the truck only works parking and stop lights not turn. I also might add it is still a 6 volt system which im not planning on changeing either. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I also might add it is still a 6 volt system which im not planning on changeing either. Good for you. Someone who can help with the wiring will be along shortly. I use the original turn signal (arm out window) so I can't help you.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Unless your signal switch was built for it you can not use the brake light circuit. You need separate lamps with most after market units. | | | | | Joined: Jun 2012 Posts: 23 New Guy | | New Guy Joined: Jun 2012 Posts: 23 | I have all the lights working. But Im using signalstat tail lights I want to use the original type tail lights I just need to know if they are made with dual filament bulbs. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Did they not originally have two bulbs (for tail & stop)?
