0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#939861 04/30/2013 6:53 PM
I have a 1950 4100. I konw it was stock without turn signals and only one tail light. when I got the truck the turn signals where already mounted on the fenders so Im not going to remove them. I have all the lights working,front and rear turns and parking stop lights. My question is can I get original equipment lights that have the daul fillement bulb? The one that came on the truck only works parking and stop lights not turn. I also might add it is still a 6 volt system which im not planning on changeing either.
Ex Hall Monitor
Ex Hall Monitor
Good for you. Someone who can help with the wiring will be along shortly. I use the original turn signal (arm out window) so I can't help you.
Unless your signal switch was built for it you can not use the brake light circuit. You need separate lamps with most after market units.
I have all the lights working. But Im using signalstat tail lights I want to use the original type tail lights I just need to know if they are made with dual filament bulbs.
Did they not originally have two bulbs (for tail & stop)?
