5 members (32Fordpuchoptop, Otto Skorzeny, Mike B, Bill Hanlon, bluechev), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#939731 04/30/2013 8:18 AM
have 2 one barrel carbs off ('53 GMC and '58 Apache), ready to order kits & rebuild. Any kits to avoid? Any kits worth paying extra for that work better/have better parts. both of the under carb rubber "isolators" or whatever they are, fell into chunks in my hands, so they come with rebuild kits or separate item? It's like a little rubber donut about an inch or so thick, I guess meant to slow down manifold heat to the one barrels (rochester). THANK YOU!
lefty1 #939754 04/30/2013 10:27 AM
The spacer block will not come with a carb kit. You can get them from any of the suppliers that advertise here. Some of the kits sold by FLAPS are a fit all kit and leave alot to be desired. Get a good quality kit and use the #'s on the carb so you get the correct kit. It will be money well spent to get the best parts you can.
