3 members (klhansen, dt235sd, 1 invisible),
67
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93940 12/20/2005 3:58 AM | Joined: Feb 2002 Posts: 36 Apprentice | | Apprentice Joined: Feb 2002 Posts: 36 | I have a charging system problem with my truck, it is a 69 chev with an external voltage regulator. First my alternator tested bad, so I replaced it. Then with still no charge I jumped the first three terminals on the regulator and I get a 14.5 volt charge. I replaced the reg and plugged it in and still no charge. Is it this regulator or something else. Can anyone let me know what the basic operation of the regulator is and what tests I can make with a volt/ohm meter to identfy my problem. Thanks, Ranger
Because of God's Grace, Ranger Ric Micah 6:8 Remember if you are driving one of those other things.....stop it! visit our homepage for pictures of my trucks and our dogs. http://www.rainydaysmastiffs.com | | |
#93941 12/20/2005 3:13 PM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | The regulator is just what it says it reguletes voltage out put from the alternator so you wont fry your battery and other electrical goodies.my personal opinion:junk the external regulator systm and instal a later model internal regulator alternator.it is easy to do and will save a lot of head aches down the road | | |
#93942 12/20/2005 6:39 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is no need to change to an internal regulated system. The system you have will do fine if everything is right.
It sounds to me like there may be an open wire between the alt and reg. Disconnect the wires and check each one for continuity. While the meter is on it wiggle the harness and see if the curcuit breaks. Replace wires as nescessary. | | |
#93943 12/20/2005 7:03 PM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | The later setup is far better and a lot less hassle when it quits charging you just replace the alternator. | | |
#93944 12/20/2005 8:26 PM | Joined: Feb 2002 Posts: 36 Apprentice | | Apprentice Joined: Feb 2002 Posts: 36 | I understand the internal regulated idea and would like that except during this time of year money is a hurdle and this is my snow plow truck and needs to be running yesterday. I just bought an alternator and they won't take it back because it has been hooked up. The open wire idea I need to pursue. I have power to terminal #3 which is from the battery, I have a 7.5 volt reading to the number 1 (field) terminal and the #4 terminal. If I jump 12v to #2 terminal I get the 13.5 up to 14.7 volts to the first three terminals. Just sitting key off should the regulator have 12v to anything other than the battery feed, how about when the key is on or the truck is running. Again I ask how does the regualtor work inside. Does the alternator charge all the time and when the battery is up to snuff the regualor breaks the contact to the battery and thus the battery stops getting a charge? Should I have power at the alternatorwhen the key is off (other than the battery hot feed) or the key is on. I get nothing at the two wire plug when the truck is running unless I jump the #3 and #2 terminals on the regulator. #4 wire (brown) goes to the engine harness connector and then feeds to the L/H parking/directional signal circut, should this be a hot wire to the regulator, those lights work but there is no power to the #4 terminal...... Should there be any other hot feeds to the regulator other than #3 constant, is there a hot wire feed to the reg when the key is on other than #3. Don't get me wrong, I appreciate the ideas but snow is falling and I'm Christmas broke.
#93945 12/20/2005 8:30 PM | Joined: Feb 2002 Posts: 36 Apprentice | | Apprentice Joined: Feb 2002 Posts: 36 | Correction I do have 7.5 volts to #4 which I stated earlier in the last post. This a corrected statement from the last line where I said I had no power to #4.
#93946 12/20/2005 11:38 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I dont have a scematic handy but one wire to the regulator should be hot when you turn on the ign. It goes through the idiot light or a resister built in the harness. One wire on the regulator is hot all the time. The field wire feeds to the feild on the alt. Yes the regulator controls the voltage output of the alt. When it gets to the preset voltage ,about 14, it tapers down to maitain that voltage. The amperage takes care of itself because the alt. will only put out its max. built in curent. Unlike a gen. which will destroy itself if its uncontrolled. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#93947 12/21/2005 12:08 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Ranger,
I am not an expert, but here are some ideas. I think you might have tried this, but I will mention it anyway. To "prove" the alternator, REMOVE THE DA PLUG from the back, and with the truck running, use a wire to jump battery voltage to the "F" terminal on the alternator.
This will put the alternator into full field charge, and with your meter on the battery, you should see the voltage climb to 14 + volts. Don't do this for an extended period of time.
With the key off, the regulator should show battery voltage on #3. With the key off, #4 should show zero volts and when you turn the key on, it should show your reduced voltage. I think you said 7.5 volts.
The schematic shows "F" on alternator to "F" on regulator. "R" on the alternator to #2 on the regulator. These wires, as was noted above have to have continuity...no breaks! I don't know what values in voltage they will have, but if all wires are intact and you can get the alternator to output by jumping the "F" terminal, it would seem the regulator is your culprit.
I know the "no returns on electrical items" is a drag, but you can see why this is the policy.
If you can eliminate the alternator, you have half the battle won. I don't think adjusting the regulator is an option open for anyone other than a experienced repair person. If all else fails and another alternator is required, a internally regulated one would be a good choice, and it could be integrated into your existing system. Good luck.
Stuart | | |
#93948 12/21/2005 1:03 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Here\'s a link that may help. | | |
#93949 12/21/2005 4:08 AM | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Make sure the regulator is grounded good, if not won't work. If working right the alterator should run every thing on the truck. The battery is really only to start the truck and the alterator keeps the truck runing. If the alterator is working right you can undo the battery and the truck will keep running. also make sure the ground to the motor, frame, body is in good shape. new regulator are not adjustable the old one were if you know what you are doing, you can fry the battery if you over charge it often.
super250six | | |
#93950 12/22/2005 8:50 AM | Joined: Feb 2002 Posts: 36 Apprentice | | Apprentice Joined: Feb 2002 Posts: 36 | Thanks for all the help!!! Never trust new parts form the parts store. Between 2 failded regulators (bad form the store) and a bad wire, not broken but could have been a culprit, so I replcaed them all. And I now have a charging system that works. Yes the one wire newer model alternator may be in the future when money is more fluid. Thanks again to everyone.... Merry Christmas to you and yours from us up here in the NorthWest. I will be a happy plow'n kinda guy tomorrow.
#93951 12/22/2005 11:08 PM | Joined: Feb 2002 Posts: 36 Apprentice | | Apprentice Joined: Feb 2002 Posts: 36 |
#93952 12/22/2005 11:24 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Ranger, What could be a better Christmas gift than a purring alternator and a frost free window! Stuart | | |
