7 members (Buckeye998, tclederman, JoergK., Gray_Ghost, carbking, 32Fordpuchoptop, 1 invisible),
108
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,192 Posts1,057,358 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 6 New Guy | | New Guy Joined: Aug 2011 Posts: 6 | No one seems to want to buy my 46 Burb, so I guess I will have to build it, or at least get it rolling...BUT !!! When I bought it, it came on a BARE Frame, no axles or springs, not even the spring mounts...SO...I have purchased all the parts to install a Mustang II front crossmember...but having NO axle underneath it, I have now way of finding my centerline...was hoping someone out there has done this before and could let me know what the measurement is and where to measure it from ??????Any and all advice will be much appreciated....might be easier to email me directly, don't get to this site [email protected] | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We build a lot of rods from scratch so maybe this tip will help. Bolt a front fender to the cab (which doesn't need to be on the frame) and then use a tire/wheel combo that is going to be on the finished project and just place it in the wheel opening in the position you think looks the best. Now measure from the front cab mount hole straight forward till in line with the center of the mock-up wheel. Now do this same measurement from the cab mount hole on the frame forward and mark the frame rail. This will be the axle centerline that puts the wheel/tire where you thought it looked the best. Also, forget the factory mounting of the rear end because GM mounted it so the rear tires are 1.5 to 2 inches too far forward or at least this is so on the 47-54 AD's.
Evan
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | That sounds like a real commen sense approach to setting up the front suspension. Not to get off topic, you touched on it but I have always wondered why the rear axles never were in the center of the rear fenders on AD trucks. Seems like the 3/4 and 1 tons were even worst that the 1/2 ton trucks. Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Aug 2011 Posts: 6 New Guy | | New Guy Joined: Aug 2011 Posts: 6 | Evan, thanks for the suggestion....bit harder with the suburban body vs pickup, but I will sure keep it in mind...
AGAIN...Many Thanks
Les | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That's very similar to how I did my '46. There was no suspension under it, so I decided where I wanted the center of the wheel and made that the centerline. The great thing about customising the truck is that you can make it look how you want it to. | | |
