1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Does the throwout bearing spin when truck is in neutral and the clutch pedal is out? Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | can do, but lazily, not 'driven' by engine speed - unless you have the habit of leaving your clodhopper resting on the pedal so it's kept pushed against the pressure plate .... got noise?
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most of the newer TO brgs have a hump or a pin on the sleeve where the fork goes to keep it from turning. If the clutch is adjusted correctly & has a return spring it will not turn without pushing down on the pedal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | PUT a mirror on a pole and i think it is spinning some of the time,kind of stop and goes.NEW spring on fork bracket.adjust free travel i think.(Clod hopper) full cleat or none.Back in my hippie days (BSA 650) we used full cleat. THanks again . | | |
