1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93907 12/17/2005 1:03 AM | Joined: Nov 2005 Posts: 22 Junior Member | | Junior Member Joined: Nov 2005 Posts: 22 | Howdy!
I took the truck out for a spin earlier today and and my keychain got stuck on my sleeve and it yanked the key out of the ignition. Truck still ran. So I put the key back in and shut it off. Took the key out and turned the truck on again without the key in the slot.
Is this a bad thing? I now know that anyone can climb right in and make off with my truck. Have to start taking my distibutor wire off at night and take the battery out to keep would be thieves deterred. Any suggestions would be greatly appreciated.
-Will | | |
#93908 12/17/2005 1:45 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | my 61 and 64 will start with the same key. | | |
#93909 12/17/2005 2:23 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Will, Start wearing short sleeve shirts!  I think a new key switch would be the order of the day. Stuart | | |
#93910 12/17/2005 4:12 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The problem is not the switch. It is a worn lock assembly. This is very common. They are replacable and most vendors stock them. | | |
