3 members (David Bush, 52Carl, Jon G), 136 guests, and 13 robots.
Topics128,078
Posts1,056,029
Members48,433
I seem to remember that a 47-54 GMC or Chevy Suburban frame can be interchanged with a 1/2 ton GMC or Chevy frame? Is that right?
the panel/burb frames have different body mounts and the tails are longer/have extensions for the bumper positioning - you could use a pickup frame if you have a dead burb frame for the extra pieces
Do 1/2 ton 47-53 panel/suburban frames have an extension on the rear of the frame rails (in comparison to a 47-53 pickup frame)? I do not think that is the case with my 3104 and 3106 1954 frames?
I used a '51 p/u frame and put a '49 panel body on it without any problems. I did have to make the middle body support and there were no frame extentions needed.
Arn't panel and subs about the same?.....Al
well, bumper to bumper measurement is over 6" longer on the same WB, however that's achieved, maybe just longer bumper irons? - on the 55-59's there's an extension added to get the extra length required to put the bumper behind [and lower than] the rear doors
Sir Searchalot
Sir Searchalot
And, as Bill has said before, GMC and Chevy 55-59 frames are a little different up front.
47/55 GMC/CHEVROLET suburban frames are almost identical except for the body mounts. The 1947/53 frames are the same between pickups, the change came in 1954 with the different bed and frame arches. The suburban mounts alleviate the frame differences between years. There is also shock mount differences with some years.
Original Question:
- 47-54 GMC vs Chevrolet truck 1/2 ton frames
- Suburban vs other 1/2 ton frames
GMONIZ has addressed the original question.
One additional difference between Chevrolet and GMC same-year frames is the front motor-mount cross-members.
